Outdoor base station plug in signal repeater
Does anyone know of a signal repeater that works with the outdoor base station. My cams outside barely have signal. Be nice if they made one I could plug in on the other side of my house to strengthen the signal. If it’s Ben brought up I did search and didn’t see it. Apologies in advance
We to the Wyze community @36dbldz!
There’s currently no way to do this other then using another base station. if you’re unable to run an ethernet cable to the second base location, you can set it up hard-wired to your router, then connect it wirelessly to your network in the base station settings.
An extender for the WCO base is currently on the Wishlist.
