Hey guys, I was wondering if there was an applet in IFTTT that would allow me to turn off my indoor wyze cams when I am home and turning them on when I leave using my phones GPS location? Leaving the one’s I have outdoors on at all times. I have two cams indoors and 2 cams outdoor.
Thank you.
Create a trigger using the location service in IFTTT. Select “when I enter” or “when I leave”
Then find your area. You can also pinch on the circle to make the area bigger or smaller.
image|382x500
Next create an action using Wyze.
Then select “turn off device” or “turn on device”. and select the camera.
Do this for the on and off function of each camera.
Thank you for the response. I was able to find this applet, however I only seen an option for 1 cam or all the cams. I would like to power on and off only 2 of my 4 cams. Am I missing something?
Thanks again.
You would just have to make this applet for each cameras you want to control.
I was able to figure it out, thank you. My mistake was going in to the wyze applets instead of location.
