IFTTT For Specific Camera
I am currently using IFTTT to turn on and off Wyze cam notifications when a switch is changed. This appears to work well.
The problem is however that the IFTTT app applies to all cameras. There is no way to specify specific cameras for the actions. Is this possible? Where or how do you specify which camera to use? Thanks
While the Wyze app has been improved to allow turning notifications on/off per camera, that has yet to be incorporated into the possible Wyze IFTTT action set. Please hop over to the post below and VOTE for it at the top of the page:
In the mean time, it is possible to Enable/Disable motion detection, and to turn on/off each camera using an IFTTT Wyze action. You may want to consider using one of these for now.
Ok. Thanks for the update on the current status. Enabling/disabling motion detection may be enough until they have additional IFTTT support.
