So if I have all triggers off within the Wyze app, but I set up IFTTT to trigger ON motion detection when I leave home, does it turn ON the trigger within the Wyze app or is it just thru IFTTT?
thanks
thanks
I think you are asking: If Motion Detection is turned off in the Alerts section of the camera Settings, will the IFTTT trigger “Motion is detected” still detect motion? If so, does using the IFTTT trigger result in Motion Detection being turned on in the camera Alert Settings?
I don’t know the answer offhand, but why don’t you be the one to test it and let the rest of us know.
