Hello People and @Ipil60R34s.
I am responding to your posts #60 and #62.
You are correct that if you or a camera is viewing the world through a narrow tube say 1 meter (about 39")long and about 63mm x 63mm square, you will only see a very small part of the world. The spreadsheet I provided a link to puts out a pattern when folded results in a square tube shield whose average length will not exceed 33mm (about 1.25"). So, when looking through this short tube, what will you see? A lot! Yes, the longer edges of the square tube will block some of the field of view. But not too much. The three pictures below are images taken of and through a square tube shield:
With a square tube shield, one of the camera’s top forward corners is always in contact with the glass. And you can see that adding up the lengths of edges of the tube will result in one-half of the width of the tube. A very short tube.
This picture is the view the camera sees. The trapezoidal tan shape visible at the right edge of the picture is the blockage of the view you mentioned in your posts.
The next picture is interesting because it was taken without the square tube but held in the same orientation as if was connected to the tube.
The dark triangle at the right edge of the picture is the frame of the window. The amount of picture frame in the view depends on how far away it’s from the camera. The side frame was about 1 meter from the camera.
When comparing the last two pictures, I think it is fair to say that not much information was lost in the first picture.
Like you, I thought maybe this was the end of the road for a better shield. One with less obstruction. The new design is called the Kite Shield. This is a work in progress and so far I am pleased with it. Below are photos of the early build.
These three photos are of rough tape assembly:
As in the square tube version, a top corner of the camera touches the window.
As can be seen, it is a crude build.
A further away view.
The next three pictures depict how effective this design is:
This is a daytime picture that shows the slender amount of blockage from the end of the shield on the right edge of the picture. The dark tan obstruction is the frame of the window, while the light tan is the inside surface of the kite. So, there is essentially no kite blockage.
The kite was manually held away from the surface of the window so glare effects could be seen.
A dramatic difference. If the shield were not in place, we would be seeing the side of the window frame. So no real loss of important information here. The finished Kite Shield will connect via a nice adaptor collar while the kite itself will be duct-taped to the window. Removing the camera for any reason will be by slipping out of its collar. In post
#59 are stl files for the collar that can be printed by anyone.
Sheet 1 of the spreadsheet that I linked in post #59 is a nice pattern calculating tool, sheet 2 provides pattern layout tips, sheet 3 covers a simple way to get the two angles needed for spreadsheet input, and the last sheet shows the effectiveness of glare blocking.
Victor Maletic.
