Notification Issue
yes, that absolutely did it. Thank you!!
I am not getting any notifications also… When is this issue going to be resolved #wyzecamsupport?
Got my v2 cameras today. Set one up the evening and have been testing it.
Essential phone running android 8.1.0
Camera firmware 4.9.1.42
Not getting any push notifications with last public release of app. But app was recording motion alerts for daylight mode, and sound alerts. Not recording anything when camera is in night mode.
Upgraded to beta version of app. Camera is still not triggering any recording or alerts when in night mode. But push notification did start working when alerts we’re triggered for sound or when camera was in daytime mode.S
Sonight motion detection is still broken in new beta.
Android beta 1.3.107 seems to have solved my V2 notifications problem on my Pixel 2. (I’m also using the latest V2 beta firmware.) I haven’t tested in night mode.
Where do you find the latest version 2 beta firmware? I would like to try… Thanks…
It’s further up the post but here:
If you are on Android, go to the play store, search for the Wyze app. Once you open the app information section, scroll down until you see the “I’m In” for the beta or something like that. It only takes a few seconds. As soon as I installed the beta app and the updated firmware, everything started working on my V1 with my Pixel 2 XL.
Just got my 2 cameras after waiting over a month to receive them. I have been testing the notifications like everyone else but am not receiving any to my phone. Running on a samsung galaxy S7 version 7.0. Wyse app from google play is 1.2.76 and the cams firmware version is 4.9.1.42.
I 'm hearing about a beta version, but do I have to uninstall the current version I have and where cann I get the beta. Thanks all.
Where and how did you get the beta app. I’m using android phone version 7.0
Uninstall? No. The beta version will automatically update your current version. (You will not have two separate versions on your phone.)
Thank you for the solution!!! I just set up the 2 ea. V2 cameras just received. I was not getting notifications of movement or sound on my Samsung S8 Android phone? Notifications were being received by my wife’s i phone 6 just fine.
I loaded the “beta android app” per the instructions above and updated the firmware. This solved the problem! Yay! Notifications for sound or movement not work perfectly on the S8 Android phone!
Thank you all for your input and help!!
( Now I will set up the 5 ea. other V2 cameras just received) I may order more.
what is the ETA very soon is very vague
no notification at all when in night mode
