No video at the selected time?
I have the newest and oldest pan cam and both have been reporting; “No video at the selected time”!
Seriously, these cameras are overloaded with useless functions to the point they can’t even perform basic functions anymore!
Tried everything and no joy!
Best regards,
Kevin
Are you using “high endurance” microSDs? If users don’t explictly mention “high endurance”, I presume they are not.
What does your reply mean? My 32gb sd card has been working for almost a year.
It means 1 year of writes may be the lifespan of that particular card. High Endurance cards can write for years (or even a decade or more) at the rate the Wyze cams write at. The standard cards are not designed for that and have a lower lifespan.
Finally removed the PAN CAM to replace the memory card. The Memory card was still good! placed it in another PAN CAM and it still works! Installed a new memory card in the defective PAN CAN and it does not work and I’m getting the “No video at the selected time”! It appears that the PAN CAM does not last more than a year being used outdoors. The same type PAN CAN located indoors and looking through a window is still working. Looking for a recommendation for an outdoor PAN CAM with high reliability. Standing by for signals
Did you happen to see what was on the card before placing it into another Cam Pan v3? I wonder if the problematic Cam Pan v3 was actually recording to the card but not retrieving recordings because of . While your problem could be an indoor/outdoor issue, I have a couple of indoor-only Cam Pan v3s that haven’t always behaved the same way. Eventually, the issues with the newer camera were resolved with firmware and/or back-end fixes.
Who knows with Wyze? :man_shrugging:
