I have 4 V3’s set up , I’m on self monitoring. I would like to add the sensors on my doors/windows. will I be able to do this without having a subscription? Also, I would like to add a wyze mesh router to my collection, also without a subscription.
I think all you would need is a hub for the sensors. I use mesh and don’t subscribe. Maybe someone will chime in for a complete answer.
@ygomez0721 - You need the Home Monitoring hub to use motion or contact sensors. You DO NOT need a subscription. The Mesh Router does not require a subscription.
thank you @ssummerlin and @Earl.Automation for your answers.
I will get a hub for the sensors. And I really want to have that Mesh
I just do not want a subscription.
thanks again
Just remember…a mesh is more than ONE router. You’ll need at least two. Also note that Mesh and Mesh Pro won’t work together. It’s one or the other.
@WildBill I have a combo. (modem/router in one) is this what you mean?
No…I mean if you want the Wyze routers to work as a mesh you need at least two. Most likely you’ll want to disable the wifi on your combo router and just use the Wyze mesh for wifi.
got it, thanks
