No QR code during setup
wondering if anyone that’s setting up a cam has had trouble getting a QR code to appear? it seems that every once in a while set up advances to the QR screen but won’t produce an image.
I have not seen this issue, but most of my setups have been on Android. How often have you seen this and do you know which version(s) of the app/iOS?
If you can reproduce the issue it may be helpful to submit log files:
it has happened with all versions of ios, maybe about 10% of the time. just a blank page where there should be a QR- then the next time there is a code and i can scan it.
