I’m also not seeing data for my Watch in the app after that date. I’m not sure what you mean by this, though:
Why can’t you submit a log? What other detail can you provide? Submitting a log and following that by opening a ticket would probably be my next steps with this.
Did you type anything in the Details box? You have to enter something there first; otherwise, the Submit button remains inactive.
After you submit a log, you should receive an e-mail message with the Log ID (the app will show you this number, as well), and the e-mail will prompt you to contact Support if you need help. Creating a ticket is a separate process.
This is how I prefer to submit tickets (you can click/tap to expand this):
Click into the “AI-powered search” box in the middle of the page and enter create ticket.
Click Yes, that is correct.
Repeat Step #3. ( UGH! )
Click No, I do not like chatbots.
Click This is about a product.*
Click Other.*
Click Create Ticket
Enter your contact details and a brief issue description (include a Log ID if you have one) and click Submit.
* Make your own appropriate/relevant choices here.[2]
It doesn’t really matter how brief the description is. Wyze’s system will generate an e-mail message to you automatically with a Wyze Ticket number, and you can just reply to that message from your e-mail client and add as much detail as you want.
I’m trying to get more information about this issue, too.
I’m demonstrating my typical path. The number of steps will likely be the same and result in the identical endpoint regardless of the choices you make. ↩︎
Thanks for the help. I did not type in any b4, now I can submit. But “fail to get log”, I tried 3 times, give up then , just have to submit without log.
Yeah, I had to do the same thing. The app (I have my Watch 47 linked to a phone that’s still running the v2.50x app) still gave me a Log ID, though, and I entered that when I created my ticket with Support. So far I’ve gotten just the automated responses to that, no human yet, but when I was able to respond to the initial “WYZE-E” message in more detail, I included a link to this Forum topic.
I was thinking maybe the failure about the log message was because I was using an older version of the app, but I suspect that this isn’t the case and that there’s some kind of backend glitch, maybe like what happened earlier this year when users were unable to pair their Watches to get them setup in the app.
FYI, I still have an open ticket with Wyze Support. Apparently they don’t have a resolution at this time, but the most recent response I received suggested submitting another log, so I did that, and this time I didn’t see any messages about failures. Hopefully that means it will contain useful data for the engineers to look at, because I still think this is a server-side problem.
Oh, and my mom is having the same issue within the same time frame, which I think is further indication that this problem is on Wyze’s side and not something going on specifically with a few Watches.
That’s what I see, too. I don’t think there’s anything you can do with the Watch that will solve this, but if you figure something out I’d like to know what it is. I really think this is a server-side issue, like what happened with Watches earlier in the year.
I don’t know what your familiarity is with log submission, but Support doesn’t see or deal directly with those, and the follow-up e-mail message should tell you that Wyze won’t contact you after a log submission. Opening a ticket is a separate process, which is why their post-log-submission e-mail also tells you to visit their support site if you need help.
I included in a post above the steps I take to open a ticket.
Thank you for contributing to this topic and sending a log! Hopefully this helps to get some attention on the issue so they can fix it for all affected users.
Has anyone been able to see an resolution for this issue? I had a ticket open with Wyze Support (I imagine it’s closed now; they do that without any sort of notification) and sent logs but am still experiencing the problem. I still suspect it’s the result of a back-end change.
Thanks for the reply. I appreciate the confirmation. If it’s still an issue after the end of this month, I’ll try bugging them about it again, even if I have to open a new ticket referring to my original ticket on this. I set a dated Bookmark on this topic to remind me to do that.
Watch is recording sleep and it shows in watch. I need it to sync to the app so it can sync to Apple Health (then to a workplace health app).
Have restarted, deleted, reinstalled, re-paired, all the typical troubleshooting, but the last time it worked was April 1. Radio silence since then. Steps DO sync to the app. Just NOT sleep.
Very frustrating that they don’t support these products any longer. We have multiple products from this company and historically have been extremely pleased. This is the third 47c watch that we’ve owned. It’s been an excellent product with an excellent price. It’s very unfortunate they’re no longer supporting their products and not addressing this issue.
My 47c is exhibiting the same behavior, data is being collected and sync’d to the app but in the daily/weekly/monthly historical graph section, nothing is being displayed after March 31.
Google Fit is importing the step count and I can see that historical data but that’s not why I bought the watch for. It does seem like a dead product and support is pretty useless overall, moving everything to AI chat bots.
@bakcrakr & @alvinychan, thank you for adding to the list of complainants. I gave up on my last ticket when a new agent stepped in and part of the reply literally said this:
I’ll be taking over your concern about XXX.
I was so incensed by the lazy response (which appears to be from a template that the Wyze Wizard didn’t even bother to edit and replace the “XXX” with the product or problem I was experiencing) that I wasn’t sure how to respond and gave up on that particular ticket, which has probably been closed. I’ll try to get back to bugging them about the issue this week. This situation is ridiculous, and that kind of response is unnecessarily insulting.
