Is anyone else having trouble viewing any recorded playback? Im able to view my events but nothing else…the SD cards are functioning and the only way I can view anything on them is to remove them and insert into my laptop…
All my cameras have had the same cards in them since day 1 . If I remove the card and insert it into my computer I can view all the videos without problem but when it comes to viewing the playback that’s on the SD card through the app it’s unavailable.
It started to work for a few hours the other day but went right back to not working on all cameras again
Sorry for the delay in my response here, so it sounds like the cards are reaching their lifetime, I would put them in a computer and do a full deep format not a quick format and see if that changes anything. Sadly memory cards do have a finite life cycle and containers recording if you happen to use that can run through it a lot quicker than event recording. That’s one of the reasons that I personally use bigger cards so that I get more mileage out of them.
@Bam I did get my recordings to show and play in the timeline for about 24 hours after a firmware update but that only happened with 1 of 5 of my cameras.
I have a subscription. I also am trying to view SD card recordings which are set to continuous but it is only showing me events and will not show meanything when I select the timeliness view
I still don’t understand why i can only view playback of recordings from a couple of my cameras. I tried new SD cards I even reset the camera and still can’t view SD card recordings
You’re right that doesn’t seem to make a whole lot of sense, and the fact that you’ve pointed out a few times the understanding of difference between the SD cards and the cloud I can attempt to speculate those confusion there. Can I ask what card you are running? It sounds like having purchased them new that definitely shouldn’t be the issue, but I try to keep a small running tally of cards that have issues commonly. Maybe I can delve into it a little bit deeper and see if whatever you’re using is on my radar already.
The fact that you said you did an actual format not a quick format is reassuring. But also confounding… When you do event recording does it record as it should?
