No L-Shaped adapter for Outdoor plug in Canada?
There is no option to get the L-Shaped adapter on the Canadian Wyze store. Is this a mistake on the website or just how it is?
Do you mean the part that comes with every V3 Pan camera? Are you trying to buy the part separately?
For the outdoor power adapter here it is on the American website Wyze Outdoor Power Adapter – Wyze Labs, Inc.
The Canadian website has the outdoor power adapter but not the L-Shaped add-on Wyze Outdoor Power Adapter – Wyze Labs, Inc. (Canada)
OP is referring to this:
It’s a short cable that allows you to plug your CPv3 into an existing micro-USB run or whatever that has a micro-USB connector vs the supplied cable that has a USB-A connector.
