I know this has been discussed in the past but does anyone know if the inability to KEEP the setting on ‘no cooldown’ will ever be fixed? It’s a huge problem for a SECURITY camera to not have continuous filming! We are seriously considering switching to Ring as I believe I read that the above Wyze issue is a non-issue with their cameras… If anyone has any recommendations I would be very appreciative ![]()
The issue of the cooldown hasn’t been fixed in 11 months so I don’t think it will ever get done. I have four WCO v1 cams so now I just use them for critter watching. You can set it to no cooldown but it makes no difference, still 1 Min. If you need to use battery cams I suggest you move to a different brand.
Thanks, I believe it’s time to switch to another brand ![]()
