I am having issues with my C wiring at the HVAC terminal. I have more then 2 C wires connected, and when I added my fourth C wire I am not getting any power to my thermostat. So I am wondering if anyone can help. I attached some pictures of both my terminal and at the Thermostat after adjustment with the new C adapter.
Thx
When using the C-wire adapter, you will have to connect the green G wire at the thermostat side (and only there) to the C terminal instead of the G.
Thanx I’ll try it hopefully I’ll work
Thanks a lot. I got it working and so far so good. I don’t how I missed it.
