Nightvision
My night vision on my pan cam is horrible. How many ir lights are there?
Hello @vzndave, If I’m not mistaken the Wyze Cam Pan has 4 IR lights same as Wyze cam V2.
@Loki correct me if I’m wrong please.
There are six IR LEDs in a Pan. :slight_smile:
Thank you @DreadPirateRush :call_me_hand:t5:
Are the IR lights burning when you turn nightvision on? I have the same issue, no IR lights burning… I just hear a click when I turn nightvision on. I checked the experience of other people on youtube who bought the wyze cam pan and nightvision works very well on their cam.
@kenkey Unfortunately, this sounds like a faulty camera.
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, I suggest you file a support request including the log files for more help. You might want to go ahead and submit your ticket now as there is somewhat of a backlog. If you end up getting the issue resolved before support contacts you, then you can always let them know that it’s already resolved.
Thanks for the response. Yes, they go on. I counted 6. I will open a ticket with Wyze.
My apologies @vzndave, my response was to @kenkey, and I didn’t notice they weren’t the OP.
Now for your issue. Since your IR emitters are lighting up, what is the area and/or distance you are trying to illuminate? Because the Pan is intended for indoor use, the IR LEDs aren’t strong enough to illuminate a large area. If you are monitoring a large area, you may need supplemental IR lighting.
No worries. Indoors. 12Ă—15 living room
There have been some firmware issues floating around with IR LEDs not coming on. I would definitely get a support ticket going. There are two things you might try yourself if you’re up for it:
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwj0aIjSUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiMi9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMTQ0NDA2OTItRmFjdG9yeS1yZXNldAY7B1Q6DnNlYXJjaF9pZEkiKTM5MDkyNTdkLWM4NGItNGQyZC1iZmQ1LTI4MmVhY2JiMjMwNQY7B0Y6CXJhbmtpBg%3D%3D--4d85594798550a67304e03097b1864e4350786a2
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwi34TzSUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiSi9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMDk0OTA4NzEtQ2FtZXJhLWZpcm13YXJlLWZsYXNoaW5nLWluc3RydWN0aW9ucwY7B1Q6DnNlYXJjaF9pZEkiKTQ0MWM1MjM5LWFhYzYtNGMxNC1iOTcyLWQ5ZDc0MWUzYTQyMQY7B0Y6CXJhbmtpBg%3D%3D--dfbd28fa94609385ba0cd2516814aae843cdc96c
Thanks, they appear to be on. I can see them when I look thru my camera on my phone.
If they are on and the IR filter isn’t the problem, then this sounds like a replacement case.
I tried a factory reset twice but it didn’t help, still no IR lights burning. I’ve made a support ticket, hope they will respond soon.
Captain Picard says, “there are FOUR lights!”
Lol. Rex
