Night Vision LEDs Not Bright Enough?
Okay, I purchased and set up my cams during the summer, and did not notice any issues with light intensity at that time. I had to shelve the cams for a couple months or so, and when I installed them again to watch for a visitor to my garage, I noticed that the pan cam lights are significantly dimmer than the v2. Both cams are set up in my garage, You can see from images attached that my pan can only see well near the lighting of the other cam, while the nearby surfaces are dimly lit by the pan cam, but the corner of the door that is open near the pan cam is in total darkness.
Too late, I’m sure, for a replacement, and, as I said, I didn’t notice any issues back when I first installed these two cams. What happened? Seems a firmware issue to me. I don’t have access to the ios app to know if that helps. Any suggestions?
How do I access my images for the Wyze cams? I was going to include a pic, but I don’t see where to do that.
No images attached.
BUT
They are much dimmer to the Human eye than those of the V2
You should be able to look at the Album, (Live StreamAlbum)
# Wyze Cam Features
Same trouble here
Hi, i have 2 cam pans V2, but suddenly one stops working in night vision mode, i have tested before all things mentioned on the Troubleshooting guides and forums
  • Power Cycle
  • Check if Night Vision is on
  • Repositioning the camera
  • Firmware Update
  • Etc
But still not working
i made this video showing in detail the tests
Wyze Pan Cam V2 Defective - No Night Vision - IR Not Working - bug - trouble - fail - YouTube
can you help me?
Thanks in advance.
