I have multiple cameras and there are sometimes no events after about 7 or 8PM and before about 5AM. I know there should be events during those times, but they aren’t there. The time frame seems to vary. I reset all cameras and restarted them. What else can I do? Thank you!! ![]()
Welcome to the Forum, @moputertech! ![]()
Are you actually using Wyze Cam Outdoor v2 or some other Cam model(s)? I don’t have any of the old Cam Outdoor models, so I can’t provide specific feedback about those, but I wonder what Cams you’re actually using and what additional detail you can share about your experience. For instance, if you believe this to be the case…
…then sharing more information about the kinds of activity you expect the Cams to capture would be helpful, as can sharing screenshots from various areas within your Cams’ Settings.
Your post also seems to imply that your Cams are recording expected events during daytime, so maybe providing more information about what your Cams do capture could be helpful for understanding what’s happening, as well.
I have four Wyze Cam Outdoor cameras and they rarely capture anything after dark when I expect them to. Night Vision Mode set to Auto all all cameras. FW version 4.17.4.450 and Plugin Version 3.9.0.
