Wow, starlight sensor makes huge difference!
Welcome back @unclerobmac!
It sure does! It’s definitely an improvement on the black and white night vision, plus it adds the color night vision too!
@unclerobmac A major difference.
Unreal. Do these come built into glasses?
Edit: Looks as if the answer is sorta, if you have $800 lying around. Cool tech.
This is just looking through a pane of glass. I learned if the camera is snug against the window it sees very well but you can’t turn on the infrared night lights. The new V3 has a better camera sensor that allows more light gathering and no need for infrared at all if there is some moonlight, street light, etc. I attach to window with 3m Command tape.
The V3 is MUCH better at color light detection at night. @Customer, what are you referring to with the $800 reference?
Something like this starlight monocular.
https://www.amazon.com/SiOnyx-Aurora-Night-Action-Camera/dp/B07HY8STCQ
