Did a search but did not find any answer, prob due to my searching skills, I noticed that continuous recording to sd card is only in one minute segments, makes it tedious to revue footage, is there any way to increase these recording segments? Thanks
That’s the way it works (good points to that and bad). There are several PC programs that can play them automatically one after the other. Many of us use VLC.
Ok thanks. Will give it a try.
