Actions added…
Turn bulb on
Turn bulb off
Set bulb brightness
Set bulb color temperature
Actions added…
Turn bulb on
Turn bulb off
Set bulb brightness
What bulb ? ![]()
Mine are still in pre-order. ![]()
There is a few people on here that tested the bulbs
What wattage are the bulbs? Anyone know? Thanks.
Wattage isn’t really the standard measurement anymore because LEDs are typically measured in lumens. Wattage equivalents are used now for us that remember ( are old enough) to have used incandescent bulbs and wattage was all we had. although being a smart bulb there is more than the LED’s to be powered. so are you asking for the actual power rating or the light level output?
Yes. For solar purposes. Thanks
FYI - 800 lumens is 60 watts. Some of us very old people still use watts (and miles and fahrenheit.).
Lol thanks! ![]()
The bulbs are rated at 9.5 watts (60 watts equiv).
Exactly what I wanted to know! Thanks DPR!
