Hi, i lost my power cord for my cordless vac. How can i get a replacement OR is there a universal one i can buy? Anyone know what size the end is that plugs into the vac?
Whats the connector? Micro USB or C if so there alk the same any cable will work
The Cordless Vacuum Power Adapter is as follows:
- 100-240VAC 50-60Hz 0.5A Input (or whatever works for your location)
- 32VDC 0.45A Output
- 5.5mm x 2.1mm barrel plug (center positive)
Good luck! ![]()
Try giving Wyze Customer Support a call:
