Need suggestions on where to mount the cam v3 using the light socket
Was wondering where is the best place to put the v3 cam with the light socket? When motion is detected and the light comes on there is a glare from the light making it hard to see. I have it mounted close to the light currently. Thanks for any suggestions!
I have mine right above the light fixture and don’t have any issues with glare, as long as it’s pointing away from the light and the light itself is right behind the cam out of view it should be fine.
I have 2 Cam V3 mounted over PIR Floods. The bulbs are cone shielded, so there is no light directed into the lens, only the field.
They do make LED flood bulbs that don’t radiate light from the sides. Perhaps just a bulb change?
