My Wyze scale does not show the body fat and not sync to app. How can I fix it?
Not know what troubleshooting steps you have attempted thus far;
A couple of common items.
- Make sure the Wyze App and Scale Firmware are up to date
- On the device you have the Wyze app installed on is Bluetooth turned on and still associated to the scale?
Is your device iOS or Android? If Android, there may be a Bluetooth permissions setting that you need to change, that I believe was reset during an Android update.
If Android, Make sure you have the Permission “Nearby Devices” allowed for the app. This is required for BT devices and if you don’t have it set, it will not work.
