I get a bunch of notifications in events that says vehicle.But there is no movement.My vehicle is parked.This happens all the time. Sensitivity is set at fifty percent.
Currently, if something triggers the camera, any AI option selected will be tagged even if the object is not moving. Therefore, if you set it up to be notified, then you will get notified as well.
I do know that Wyze is currently working on AI notifications only when the selected AI option is moving. So once released, you will only be notified when the vehicle is moving.
If you would like to post the Event Recording Settings and Notification Settings, turn on Motion Tagging then post the Video captured so the community can analyze and let you know what may have triggered the event.
