Multiple thermostats
I have a newer home, built in 2018. It has 2 HVAC units and 4 thermostats. Can I buy 4 wyze thermostats and have them connect? I know nothing about this stuff. Thanks
Welcome!
I would highly recommend using the Compatibility Checker first. Do you know if you have a Furnace-A/C or Air Handler-Heat Pump systems?
