Multi Camera View -- more cameras per grid
You can see 4 simultaneous feeds using grouping. But I agree, its a real limit. I have 12 cameras. ts one of 2 of biggest gripes and I’ve asked Wyze to do this many times.
Place them in a group. Your are then able to view multiple feeds in order of your choosing.
How do I change the order of my feed?
I desperately need this.
I’m ok if it poles a still picture from battery cameras every minute, and does a low bitrate live view, rotating thru the cameras.
You have motion detection, so it would be cool if the app only sucked up the bandwidth when motion was detected, and did still pictures every so often.
If you sold a DVR we would probably buy that.
We do play to buy your camplus at all 4 places where I installed cameras, but they are going to do the unlimited and have a lot of cameras installed.
of these people, 2 of them would use a device that showed on their main TV, and maybe even buy two each.
If you had a virtual device, like a video combiner that had a bit of a subscription to multiplex cameras or have them rotate, so the detail view switches between cameras, or that your cams would work with a 3rd party monitor… We’d pay
If you had a chromecast like device that just had your app on it I would buy it if it could show 2, 4, 6, 8, 9,12 cameras, had a few different grid options
It would be slick to have this be an app on firetv and roku, samsung etc… even if it is very basic I’m sure the codebase is basic.
In the next update can you please add in live view setting the ability to choose your columns and rows of camera’s. For instance on another app. I have my up camera setup where in vertical on my phone it displays 2 cameras wide by for cameras down so that I can see 8 cameras on one screen without scrolling. Then if I turn my phone horizontal I can see one camera full screen and scroll for the rest. It allows me anything from a 1x1 to a 4x4. See the photo.
Thanks Scott
We use the web view. That allows for more cameras in the view.
I hope it pulls from the lan rather than bouncing thr cameras everywhere.
I can see why they would invest in few platforms. They charge so little for their stuff.
in the app edit the group. I saw the gear, then there is a cameras in group then you can drag the double bar on the right to re-order the cameras.
This is offtopic, but I feel your pain.
This will sell many more cameras.
that should be like having many thumbs up.
I’m really surprised this hasn’t been added yet. TINYCAM is SOOOO UNRELIABLE. Please please please add this feature! Makes me want to go back to wired POE cams with BlueIris, but they are a pain to install easily.
