Mounting Tape Recommendation? (For Keypad)
I’d like to mount a keypad at my front entryway, which is completely brick. I’m very reluctant to drill into the brick (or the door frame) for a keypad that I may not even use 5 years down the road. Does anyone have a recommendation for a tape style adhesive that works on brick, but also removes cleanly with some elbow grease?
I’ve seen the heavy duty outdoor gorilla tape, but it indicates that it’s a permanent solution.
Thanks!
