Not sure if others have done this, but I took my wyze sense apart to see if I could rotate the antennas another 90 degrees so they will stand completely vertical and upright. I’d like to mount my hub flush on a wall for best coverage. On my unit, the two wires that feed the antennas did not get pinched or kinked in any way as I rotated the antennas upward. Maybe this is common knowledge. But I’m happy I can do this because I’d like to install some door sensors pretty far away from the hub and I think this will improve my range.
Also I exposed the speaker. Thinking of installing a switch so I can manually disable the speaker on the hub. This would be easy to do.
