Motion Sensor Sunrise/Sunset
Has anyone got the motion sensor to work with sunrise and sunset? Here is what I am trying to do. I have the wyze bulb and motion sensor in my office. I have the motion turn the light on when I come in the room. The thing is it does it all day. I just need it at sunset to sunrise. Looked at IFTTT but sunrise and sunset will only control the cam.
Currently, unless I am mistaken, there is no way to do this unless you are running with another system, for example I am able to make it work because I am using SmartThings and virtual switches to make it work. Just utilizing WYZE I do not believe it is possible yet.
Please see this Wishlist request. It may be what you’re looking for.
I need to control my Wyze bulb to go on when motion detected via motion sense, between dusk & dawn. The off part is easy.
