Can a camera be monitored on a laptop? Its a windows 11.
If you have a subscription to Cam Plus you can use web view to monitor them. Otherwise you’d need to look at using an android emulator to run the Wyze app on a PC.
Welcome to the Forum, @dlyeagley! ![]()
What answers did you find when you searched the Forum? In addition to trying an emulator or Web View (you didn’t mention whether or not you’re using a subscription), there are other options, depending on what devices you’re already using and what your goal is:
Also, Wyze has been testing RTSP on two camera models (currently only Cam v3 and Cam Pan v3), and that feature would make it possible to stream directly into something like VLC media player, which might be the simplest solution if your PC and camera are on the same LAN. Unfortunately, the RTSP beta firmware isn’t (yet) available for Cam Floodlight Pro, but several users have made it clear that they’d like to see Cam Floodlight have RTSP support as Wyze extends this feature to other Cams.
