How do I go about checking my cameras on my laptop besides on my phone via the app?
Google:
wyze rtsp
… example
cruf1966 - do you have PC or Mac?
You can install a Android emulator, and then install the Wyze app, or, you can install the RTSP firmware, and then use VLC to look at the stream.
Too bad Wyze don’t care to make a native app for Windows / MacOS.
HP Laptop I have the youtube how to video saved.
I agree. I have a Mac, and setup Bluestacks 4 (an Android emulator), then from within it downloaded TinyCam (free or $3 - worth it). It’s very easy to set up, and it supports WyzeCam (reg or pan). I can see all 4 cameras on my Mac at the same time. Bluestacks 4 is also available in 32- and 64-bit versions for Windows. Bluestacks: Download BlueStacks - App Player on PC - Windows and Mac
Thanks :+1:
