Monitoring full screen on iphone XR?
Hey guys, when I select the ‘Monitoring’ option on my iphone XR, both cams occupy half of the screen, is there any way for me to get the 2 cams to show on the entire screen please as I do not need all the info showing on the bottom half?
There isn’t going to be a view where 2 cams can take up the full screen since the aspect ratios aren’t going to line up that way.
You can do a little bit better by adding the two cams to a “cam group” and viewing them there, that will take up a bit over half the screen in portrait mode. Landscape will just be half the screen and a bit smaller (landscape is good for any number other than 2 cams, sort of useless for 2 of them).
