Monitoring 4 cameras in 2 separate locations
Hello all. I have 2 Wyze cam v3 cameras at my house monitored with a Cam Plus subscription. I will soon be installing 2 more of the same model cameras in another location with different wifi. I understand I can’t monitor all 4 cameras in one instance of the app. How do folks do this? Thanks very much.
Set up all cams under the same account (same userID/password). They will all show up in your Wyze app regardless of where they or you are. The only exceptions are related to localities where video is blocked by authority and multinational communications protocol incompatibilities (rare).
To build on what @Seapup wrote, if you put all 4 cameras into the same Device Group and/or select them on the Monitoring tab, then you should be able to view all your streams simultaneously, provided you have reliable network connections and don’t experience the issue of being unable to view your Live Stream when not connected to your LAN Wi-Fi.
