Ability to view all cameras at once or select a few cameras to view at the same time
It would be nice to be able to be able to view all my cameras at the same time or select a few cameras to view like a security monitor. Right now I can only have one camera on live view on my tablet.
[Mod Note]: Post was moved to this category as your request is satisfied by existing functionality.
Welcome to the Wyze community jlilnc14. If you create a Device Group for your cams, you can live stream up to 4 cams at a time with your phone/tablet in landscape mode. If you added more than 4 cams to a group, swipe to the left to view additional cam streams. Or you can create an additional group.
In portrait mode, grouped cams are presented vertically and the number of live streams displayed is dependent on your device’s size/screen resolution setting. In portrait mode, scroll up to view additional cams in your group.
Tap one of the cam live streams in group display to view a full-screen live stream from that cam. In landscape mode, tap the screen again to display stream info and control icons.
To create a group: Wyze app Home > “+” in the upper left hand corner > Add Device Group > Camera Group > Enter a group name > Select cameras for your group > “Done” in upper right corner. You can then click on the camera group icon on your Wyze app Home to view.
You can rearrange the order of the cams displayed in your group view via: Wyze app Home > Click your group > Settings (the gear icon in the upper right) > click the green x number of cameras in Group > rearrange the camera order by dragging with the handles on the right (2 horizontal lines) > Save in upper left.
Note that the amount of cam live streams you are able to simultaneously display without lag, freezes and other abnormal behaviors is in direct proportion to your viewing device’s connection speed and ability to process and keep up with video streams. For example, if you’re trying to view a group of cam streams on an antiquated cell phone using a slow 4G cellular connection (vs high-speed WiFi), you may only be able to simultaneously view 1-2 HD quality video streams.
You can find more info about groups and other info on the Wyze app support pages here:
Creating a group does NOT allow you to view all cameras at once since it requires you to scroll down to see more than two cameras. I can find no solution that allows one screen on a tablet to show all my 4 cameras. I do see many users have requested this feature for many years. Is this really not yet available?
Bring this feature back! The new update only allows for scrolling multi camera view?? It was great before to have wyze multi camera view open on an ipad or iphone that I could leave open and see all the cameras. Now with the scrolling view it is a lot less organized not to mention you lose the camera view when your phone display auto locks. Defeats the purpose.
Have you tried viewing camera groups in landscape mode on your phone/tablet? On my iPhone and iPad I get four cameras on screen simultaneously. Screenshot from my iPad:
Yep. That’s what I used to see. I have 10 cameras in this group. It was Great. 4 at a time while swiping across But now it’s scrolling only. When the phone auto locks, I also lose the ability to see the cameras.
I can see four live cameras on my phone whether it’s in landscape mode or not I have all my cameras grouped and if I scroll down I can see the next four cameras and so on. I’ve been doing this for the last year
