camera does not recognize Samsung 32GB 80MB/s EVO Select Micro SDHC Memory Card (MB-ME32DA/AM); I have unplugged several times, to no avail. Any suggestions? tia
I had issues with an SD Card and when I plugged it into a Windows PC, it has two partitions on it. The camera can’t deal with a multi-partition card. I would suggest formatting it in your Windows pc after clearing the partitions (if that is the case) and then try it again in the camera.
Remember to format it once you put it in the camera as well.
after letting it set unplugged for a half hour; it recognized it after restart. thanks for your help
