Just received my Cam today…and when I insert the memory card it will not stay or click…is this expected or should it mount in? Support is very busy and I am just looking to see if I should process an RMA.
Thanks.
Thanks.
Make sure you’re pushing it in far enough to engage by using the end of a large paperclip or something similar.
That Worked…Thanks.
Glad to help.
My memory went in but il not getting continuous recording.
