Manually assign unidentified or misidentified readings to correct user
The Wyze App should provide a way to assign unidentified readings to a user, or to reassign misidentified readings to the correct user. Here are two use cases that I encounter frequently:
  1. A user’s weight has changed significantly between readings, so the scale is unable to identify the user. We have two homes with a Wyze Scale X in each. When we go from one home to the other, a user’s weight may have changed since the last weighing at the other home, so that the scale no longer recognizes who they are. The reading simply disappears and there apparently isn’t any way to recover it.
  2. Two users have very similar weights, and the scale sometimes assigns the reading to the wrong user.
I’m aware that the user can force the reading to be assigned correctly by having their phone open and running the Wyze App. But most people don’t keep their phones in the bathroom!
The scale and the app should be smarter than this. Clearly, the scale is remembering all readings. The app should provide a way to review those readings and to manually assign them to the correct user when necessary.
