I’m just trying to get the controller to go on several times a day for 10 minutes each on a couple of zones. How do I program this thing to go on when I want it on and off when I want it off, not on their broken up schedule? I just want to do a simple program that I set.
Cool, thanks. I’ll give it a try!
I just tried it with a 10 minute run time. It ran for 4 minutes. I’m guessing it will run again for 4 minutes later and skip the other zone I programed. That’s what it’s been doing. I just want full programming control for now. I don’t want it to choose when it waters. It says they there is 1 hour 10 minutes to go on a 10 minute program
No skips here. It will run the 10 minutes of watering but it splits it up with 4 minute watering then 30 minute soak times in the middle. Very frustrating
Cycle/soak turned off?
I guess I’m not sure where that is. I think that would do it though
It appears that was it! It is a plus option and I hadn’t activated it until I was sure I wanted the controller. After I did, there was the option. Thanks for all your help
