Looses power....goes dead
Every day or two my Pan Cam seems to loose power connection. Power is on at outlet…but it shuts down on its own. Have to actually unplug it and plug it back in to bring it back to life. Works great for another few days…then dead again. cannot restart from app…have to actually unplug and plug back into electrical outlet.
Any thoughts???
Make sure you are using the included power wart that comes with the camera. The V1/V2 warts only output 5V/1000mA. The Pan Cam wart outputs 5V/2000mA. You can check that by looking at the print on the power wart, itself.
Will check that!! Thank you. I am using the one that came in the box…but I will check and make sure. Mistakes do happen!
Thanks again.
