I vote (not that there is a vote) for local NAS storage but without having to use some special firmware. Everyone I know has some type of NAS on their local network, I prefer QNAP.
If you would like to vote for NAS, you do that here:
I have a bunch of cheap $30 wifi âspyâ cams that let me set the video record on alert times to 1-10 minute intervals. They require no subscription service or anything, they just start recording when an event is triggered, and stop at the number of minutes I set, if the alert is still triggered, then they start right up recording the next X minute clip onto the micro SD card.
This has really been my only real complaint about the Wyze cams. I have my other cams set to 5 or 10 minute recordings, but with Wyze, I only get a few seconds, and there are a lot of gaps where it didnât record for seconds or even minutes between recordings, even though there was motion in full view of the camera the entire time.
Letting us use our own cloud storage would be nice as a way to fix this. Or someone mentioned giving us less days and longer videos. How about we get a set amount of space instead and we can choose our own length of video? And then when the space is full, the oldest videos get deleted. I donât think anyone will wait to download the videos of criminals breaking in for 14 days anyways. But to cut the videos off at 12 seconds when people are still in frame, moving around, and causing trouble isnât good. And whatâs with the cool down period? These cameras are marketed to be security cams, so to say they shouldnât be used for security, seems very silly to me.
I would be very desirable to be able to select the pre- and post- event record time. Eg I would like to be able to select for example to have the event recording include 5 seconds BEFORE event detection and 20 second AFTER event detection.
I have the camera installed outside and it often cuts off before the actual event is over.
Seems 12 sec duration sometimes starts too early as someone approaches and ends before they come into close view. Maybe allow for user controls such as event start delay maybe 1-5 sec and event duration maybe 10-20 sec. Something like this could help a lot.
The 5 minute cool down period is kinda too far and long in between motion detection for each event. Perhaps giving the option under settings to set this âcool downâ period for shorter time frames during each event, like 1 minute or 30 seconds. When important events arise, we will need the cameraâs rolling continuously. Perhaps having the events trigger the SD card recording for at least 5 minutes at a time would be a great feature to have under settings.
If you have the SD card set to record on motion it will record in 1-minute increments for as long as there is motion. It is not restricted by the cool down rule
Jason is right. I have my cameras set on continuous recording, and it records 24/7 to my SD card. I donât miss any events at all. I can go to play back and view any recorded footage needed.
I would love to have a longer recording time (I think itâs like 12 seconds or something) but I use these cameras as security and to watch my dog and 12 seconds is just not enough time to see whatâs really going on. On top of that I have my cameras to record sound and motion and it doesnât do it all the time. Everything is up to date so I donât know I want stuff to work completely and longer record times
If you read the specs and details, it talks about the 5 min cool down between events which are a fixed 12 sec. Iâve had a lot of misses when someone comes to drop a package triggers the event when they first drive up, the 12 seconds pass and it completely misses them walking toward the door. Iâve tried to reduce the detection zone to avoid the curb out front but the position right now makes it difficult. I have no power outside so no option to mount it in the best location. The only option is to record continuously to the SD card and view playback if still available depending on SD capacity. However for checking on dogs or kids or parents, etc, you can view the live stream. All these require you got access to the app because thereâs no option to view via PC or browser.
Thank you I know that but the 12 seconds thing is whatâs bugging me the most.
Personally, Iâd like to see both a delay and some extension of event time. Something like a 2-5 sec delay and then maybe 15-20 sec of event recording. There is a corner at my walkway and once it sees an approaching movement it starts, sometimes itâs just shadow moving, but if a person does not immediately turn towards the door, then it sometimes ends before they get to the door area. Iâm trying to tweak the detection zone so it wonât trigger until after the corner but then the view misses part of the landing at the entry.
If had an AI request, it would be to recognize speed so it could ignore passing vehicles. Even in these small community streets cars move at 10 mph or more.
With the current video length set to 12 seconds, if I want to view more time itâs a multi-step process:
- Make a note of the event time and back-out of the event
- Switch to Home
- Switch to the corresponding camera - wait for it to load
- Press âView Playbackâ
- Scroll through hours of video to find the precise time of the event
Itâs so much easier with my other security product.
As a new user this is news to me⌠I have no SD and I can still see small events detected and recorded⌠granted thereâs a little delay but I donât get the 5 min cool down⌠did you mean to say 5 seconds? Thanks
Iâd love to be able to set a custom clip length where the recorded clip would be X amount of seconds or even minutes or shorter if nothing is detected after the initial triggering event. If writing on the card and not recording continuously shouldnât that be achievable?
The SDcard will record events with no cool down, but the events sent to the cloud there is a 5-minute cool down between event videos. The SD card and the cloud events are 2 separate items.
The SD card if set to record events only works in the following way:
- The camera records a 60-second video
a. If motion is detected video is kept on the card
b. If no motion is detected video is deleted
So when you look at the card you will get any minute that involves motion saved.
Thanks Jason21271
Got it⌠but I was referring to the cloud ones since when I did a test a had a bunch of 12 sec clips that got recorded with no 5 min cool down. If indeed there is a cool down period though Iâd love to see the RTSP in the standard firmware so I could use my own NAS for all recordings.
Thatâs how the event recording should be explained in the WYZE FAQ section! Thanks again Jason! ![]()
