I noticed recently when looking at the live feed there is a long delay between the actual motion and the live feed on my cell. Sometimes as long as 27 seconds. Is anyone having this experience? I’m using an Android cell phone.
Sounds like you may have been affected by the loss of Android hardware acceleration in the app.
You can downgrade to V2.4.82, the last version with hardware acceleration.
- Uninstall your current app before installing the older one.
- Enable the hardware video decoding option after installation.
- Turn off automatic app updates to prevent upgrades to the app.
You can find V2.4.82 here:
https://support.wyzecam.com/hc/en-us/articles/360009818512-Android-Wyze-App
Thank you, that was the solution to my problem. And thank you for your quick response.
