Location Triggers usually don't work
Has anyone had success with Location Triggers working? For a long time I submitted logs as Wyze support structure suggests/requests. They gave me lots of to-dos and I spent a lot of time recreating triggers, logging, etc. I implemented everything asked and still very inconsistent behavior other than the triggers usually DON’T work. I had tickets back in 2022 and finally was assured they are working on it and it WILL be fixed. NOTHING as far as I can see has been done. I appreciate any tips or updates. Thank you.
I am sorry you are having troubles with location triggers. What kind of triggers do you have set up? I am using two currently and they seem to be working fine. I have one that turns on a plug when I arrive home and one that turns on a camera when I leave home and off when I return.
