Live Feed via browser?
Is there such a method to making this possible, id like to view my live feed while on PC or Meta Quest and these devices do not support android or apple apps natively, thank you in advance
Welcome to the Forum, @joncrumar! :wave:
I believe what you’re asking about is probably addressed by Wyze Web Portal (formerly Wyze Web View, though they still use that label in some public documentation). Note that using Web Portal/View requires a subscription to a Cam Plus or higher tier and that only certain browsers are supported. I don’t know what browser(s) you have available with a Meta Quest device.
As far as PC viewing is concerned, some users reportedly like doing that with an Android emulator (BlueStacks is one example), and there are other third-party solutions that can be employed for PC viewing and doing more advanced things (like rolling your own NVR). You can find more information about those possibilities by searching the Forum.
If you have a M1 or M2 Mac you can download the iPad app and run it on your Mac. It works the same as on iPad.
That’s actually pretty cool, and I saw something to that effect in a recent topic title, but it didn’t stick with me (I’m also not a macOS user). Thanks for adding that!
With Windows 11, Microsoft provided a way to run Android apps via Windows Subsystem for Android, but they’re removing support for that feature next year and I’ve read that it doesn’t support direct access to apps in Google Play Store anyway. I’ve also not personally tried to use that, so I can’t provide any insight on how well it works.
What I like about it the most is that I can have it in full screen on my second monitor whenever I don’t need that monitor.
[Mod Note]: Personal information in attached graphic has been redacted for privacy and security reasons.
That is really cool that you can run the app natively on a large-screen device without some third-party streaming or casting apparatus.
:+1:
No :raccoon:(s) on your cabin deck, you should be ashamed, you’re not using it. :grin:
Nobody stopping them from going there :rofl:
Funny that you mentioned, but I haven’t seen any :raccoon: :raccoon: :raccoon: since last summer. :thinking:
