Limited Number of Cameras to View in One Session
I have four cameras installed, and plan to install another 1, possibly 2.
The problem is that I can only view two at a time from my phone (Android). I can view two of them, get out of the app for a little while, like five or ten minutes, then it’ll let me look at 2 cameras again before it times out on me. And it doesn’t matter which cameras I look at it. Just two at a time.
Any suggestions for changes that will allow me to look at all of them in one session?
Hi @stingray77080 welcome to the community!!!
Have you combined all the cameras into a group?
https://support.wyzecam.com/hc/en-us/articles/360030146191-Group-and-Sort-Products
Yes, if you group them, then turn your phone to landscape, you should be able to see 4 at a time.
You are on Android though, and they (temporarily?) removed hardware acceleration for Androids. That will complicate things if you are on an older device. Some older Androids can’t see 4 devices at once without hardware acceleration.
That brings me to timeouts and having to wait 5 minutes – this shouldn’t be happening, again unless you are suffering the woes of no hardware acceleration on an older Android device.
Great point - if you do have an older Android (read as not brand new), here are some resources to get it working for you:
Here is where you can download version Android V2.4.82 - which still has hardware acceleration:
https://support.wyzecam.com/hc/en-us/articles/360009818512-Android-Wyze-App
wishlist to restore hardware acceleration:
Thread disccusiong topic:
Plus, when you have more than four in a group, you can swipe to view the closest four together.
Awesomeness everyone! I have a newer Samsung, and grouping them worked perfectly and quickly! Thanks so much for your help. I love these little cameras that do their job in a big way, and for a very reasonable price. I’m so glad a coworker turned me on to them. Guess I need to start looking at your other products now!
Here ya go
