If I have a Wyze bulb do I need to leave the light switch on or does the bulb do all the action itself?
Light switch turns off power , do light bulbs work with no power?
If you don’t leave the light switch on, the bulb won’t have power to operate. So… Yes, leave it on.
I figured it didn’t have to be left on it just seems like there will be power consumption that will be a unnecessary even though the light is not on if the switch is on it is drawing some power
I would love to see Wyze get in a Integration with Logitech Harmony remote’s. That would be awesome
Power consumption is About a half of a watt,
