Light strip pro scene bug?
Hello all. I’m not sure if this is a bug, or I’m misinterpreting the device message/limitations.
For my light strip pros, which I love, I understand that you can have a maximum of 10 scenes. Is that per device/group, or ALL your strips combined?
Here’s the issue. I have 2 sets of 2 pros in my house. One set/group of 2 in my living room, and one in my bedroom.
I have 6 scenes set for my living room, and 5 for my bedroom. When I try to create a new scene, regardless of room/group, the app says I can have a maximum of 10 scenes. I was under the assumption that was per group. If it’s just total, I’d understand, but if that were the case, why do I have 11 scenes between my two groups?
All sets are updated, and I even factory reset them after I lost power for 3 days in April due to a snow storm.
Thanks for any insight or help you might have!
