Total Shame on Wyze that this is happening also now on V3 Pans.
It seems on the V3’s that I had debonding of the lens and water intrusion that they all had the sun hitting the lens at some point in the day which may have degraded the adhesive they use then over time let in moisture.
Hope your V3 Pan is under warranty, if so get Wyze to replace it
