Can they be used outdoors and connected to a 12 volt power supply?
The pros have a rubber protective coating on them, so they should be fine but they aren’t rated as waterproof so use at your own risk.
Got it. Can I wire them to a 12volt v=battery directly?
Not sure, @R.Good has played with them so he may know.
Thanks! Ill wait to hear from @R,Good
This I have not done sorry. All mine have been plugged in directly to outlets.
And official word from Wyze on using light strips outdoors
And I say this with all caution and at your own risk. But if you can Be curious, just know it may void the warranty.
Thanks. I may experiment and report back.
