Installed 6 new leak sensors (2 with probes) 0.0.0.11 using sensor hub 4.32.9.264 and iOS app 2.32.0 (20).
Operational tests worked as expected.
However, application firmware showed probe notifications enabled for the 4 sensors without probes.
Might be just in case you add a probe. Doubt you will get any notification otherwise.
