Lamp socket voice command to turn bulb on/off?
Does anyone know the Google Assistant/Alexa voice command to turn on and off the light in the Wyze Lamp Socket? I’ve tried several guesses with no success.
Also, the skirt of the fixture into which the Wyze Lamp Socket screws prevents the Lamp Socket frim making electrical contact. I’ll check the lical hardware store, but does anyone know if a bulb socket extension is sold in stores?
Have you linked your Wyze account to Alexa/Google?
Thanks for responding, WildBill. Yes, my account is linked and works with otherwise products. Just not sure if there’s a command or not. It’s simply won’t fly with my spouse if she has to open an app every time she wants to turn that light on LOL.
Also, fyi, I did find a socket extender at home Depot for about two bucks. It’s bigger than I would want, but it will do the trick.
Paul
  • other WYZE products.
Did you look at the device list for Alexa? How does the socket appear there? Can you turn it on/off manually with Alexa?
Im currently tied into the Google Assistant ecosystem, not Alexa. So I cant answer at this time.
In my case the light socket/camera combo is named “Deck Camera”. I’d think there would be a common command, such as, “Alexa, tell Wyze to turn on Deck Canera Light” or “Hey Google, turn on Deck Camera Light”, or something similar. Wyze doesn’t seem to identify the Lamp Socket with a different name/ID from the camera it’s powering. I can control the light from the Wyze app: I’m hoping there is a voice command to do the same. (Hopefully that made sense).
Not sure how it works in Google land, but there should be a unique name for the light. Does Google show lights and switches as unique objects? The socket should show up as one of those, if it works at all. May still be missing as it is so new.
Following up (to keep thread alive): does anyone know the Alexa/Google Assistant voice command to turn the light bulb aspect of the Lamp Socket on/off?
There isn’t one. I just spoke to someone on the official Twitter. Very disappointing.
Thanks; I should have posted that I eventually got the same answer. I’ll try to remember to submit a future enhancement request.
Happy holidays all.
Paul
I just created one
Will it be possible to add this functionality to the socket in a timely manner without having to get a new socket? This is a feature that I very much need and was surprised to be reading this after I just purchased 5 sockets.
It feels like a very obvious requirement.
Hopefully they add it in soon. I wouldn’t have even bought them if I had known.
Discovered today that the lamp socket is a zombie without the camera. Not visible/no control unless the camera is plugged into it. So can’t turn on/off the bulb if it is independent from the cam. Not necessarily surprising. But itdoes make me wonder if it has enough smarts that hey’ll ever be able to add indeoendent voice control of the lamp.
Time will tell. .
February 2024. Still no voice commands?
What? I have to get off the couch!!!
Listen Wyze people tell your AI thing to program this feature into the software and update the firmware. Pleeeeaaase. I would have to loose 20 calories to get off the couch, and can’t afford that in my emaciated state,
I’ve got a couple of Nordic style ceiling lamps connected through the Wyze lamp socket, and I can’t control them directly with Alexa either…only by controlling the camera. It’s a bit annoying, especially since the camera powers the socket, so it feels like we’re stuck with this setup for now. Would be nice if the bulb could be controlled separately.
They’ll eventually release the Lamp Socket V2 which will probably lets you control it separately since it’ll have 2.4GHz WiFi chip in it. According to FCC label here, they have bumped up the USB power output from 5V 1 amp to 2 amp (for supporting Cam Pan V3 and Cam V3 Pro). However, maximum power decreased from 30W to 20W.
